First Retaining Wall I have Built & wanted input, I actually rebuilt it & with some Help from other Landscapers they helped with the design to relieve the water. This is the 4 time its been rebuilt with a drainage system cause it keeps blowing out
Critique my Retaining Wall
To start off with, I'm nit picking the one thing I do see and dislike - specifically for an HOA home.
Possible to cap with a mesh of some sort those pipes? Something decorative? Also stop anything from crawling up there and croaking - which could clog drainage.
It's hard to say how good/bad it is since a lot of the details that need to be known are hidden behind the stone/underneath. Can you provide more about what was used behind the wall? Stone, sand, dirty, drainage...etc
I read this in a magazine once for places where the wall does not drain as fast as the water builds - to glue to retaining wall stones to each other with a masonry type glue. Never had to do this, but thought it was a decent idea - AS LONG - as the water is actually draining.Originally posted by MR EDDU defend him who use's racial slurs like hes drinking water.
Originally posted by ceyko View PostTo start off with, I'm nit picking the one thing I do see and dislike - specifically for an HOA home.
BEFORE
Just the stone you see & it was all one level & not stepped. But the contractor who built the house used his base bricks level with the soil on the property & not the sidewalk & that design was great till the sidewalk was installed & thus the bottem Base bricks tilted towards the sidewalk which I think contribute to the wall blowing out, Behind the Contractor Bricks he had Geo Grid with nothing but sand behind the bricks with no drains
AFTER
I dug out about 4 yards of Dirt & Sand & then re installed the Geo Grid & layed about a 8 inchs of 1inch River Rock & packed it & then installed a drainage tube with a sock over it to keep debris from packing it & then covered the drainage tube with the Same 1inch River & replaced all the Dirt & Sand I took out with 1inch River Rock to the top of the wall.
Also on the base bricks I took those up & ran the base bricks even with the side walk & dug out under the base bricks to that thick Gumbo Clay for the first layer of bricks
Def needs to be capped off. But problem is the Bricks on this wall are contractor bricks & 30 of the old contractor bricks couldnt be reused as they had morter all over them. Well the bricks they sell at Home Depot & Lowes are not Contractor size bricks & after pricing the bricks they came out to $5.37 each brick +tax to run the wall even I bid 40 bricks & this threw my Budget to hell. So for now till Budget allows for new bricks, Gonna run with this.
One of my Landscape buddys suggested weap holes every 6 feet. So gonna go rent a 1inch Drill & drill Weap holes & run 1inch pipe about 1ft up from the base of the wall to help relieve the water since the house doesnt have a Gutter system. I really dont want to have to rebuild this wall again! Some people say the French Drain Design I did with the Drainage pipe is good enough & the weap holes are overkill. But I think better safe then sorry!Last edited by SEB; 05-23-2012, 07:19 AM.GOD BLESS TEXAS
August Landscaping
214-779-7278
Seb's high class.
He'll mow your grass.
He'll kick your ass.
He'll piss in a glass!
(Note - I have zero experience building this type of stuff)
I second the mesh cover idea.
Also on the long side, purely for aesthetic purposes, I would space those layers out so they slope down more evenly. There may be a reason for the way you did it, but I think it would look much better if it had a gradual slope."A government big enough to give you everything you want, is strong enough to take everything you have."
-Gerald Ford/Thomas Jefferson
Originally posted by slow06 View Post(Note - I have zero experience building this type of stuff)
Also on the long side, purely for aesthetic purposes, I would space those layers out so they slope down more evenly. There may be a reason for the way you did it, but it looks a little odd.
Yes I actually have the caps for the two drain reliefs that come out the corner. Just didnt install them yet. I was more concerned with it doing its job & focus on the aesthetic look of it with the caps. I think 30 to 40 more bricks to run even & then cap it off at the top.GOD BLESS TEXAS
August Landscaping
214-779-7278
Seb's high class.
Looks good. I had a guy bid to redo a retaining wall, and he stated that if its greater than 3 feet high, it needs drains every 4 feet otherwise the amount of water would push the wall out over time. How many drains did you do?2012 SRT8 Challenger 392 Hemi-6 speed
Speedlogix Catch Can
Resonator Delete
Originally posted by STRONGNUFF View PostLooks good. I had a guy bid to redo a retaining wall, and he stated that if its greater than 3 feet high, it needs drains every 4 feet otherwise the amount of water would push the wall out over time. How many drains did you do?GOD BLESS TEXAS
August Landscaping
214-779-7278
Seb's high class.
Originally posted by SEB View PostYour talking about the top layer of bricks correct?
I wasn't thinking a solid wall but obviously that would look good. I was thinking if you were going to leave the ends of the layers sloped like they currently are that you could get maybe 10 or so more bricks and even out the ends so they slope more evenly.
That spot where you drop down two layers at the same time is what sticks out to me. Even that out and I think you improve the look significantly.
If I'm doing it I make the ends of each row touch this line.
Either way it looks good, I hope it drains like you need it to."A government big enough to give you everything you want, is strong enough to take everything you have."
Originally posted by slow06 View PostIn this case it's all bout function before form, but IMO paying attention to those little things will keep your customers coming back. Sounds like you got it handled though.
GOD BLESS TEXAS
August Landscaping
214-779-7278
Seb's high class.
Originally posted by forbes View Postthe pipe on the left is going to be a fail point. notice how the joint isnt supported above. it will cause a domino effect. at least that is the way the picture looksGOD BLESS TEXAS
August Landscaping
214-779-7278
Seb's high class.
