More low 9's....
  • More low 9's....
    Some video from our NHRA license test passes today. More to come soon! (including that elusive 8 second ET)
    Nice runs.....
      Foot brake??
      THE BAD HOMBRE
        automatic?
          That little sucker sounds healthy and runs great.
          My mom had a white '92 Plymouth Laser. It's what I learned to drive a stick in.
            Thats pretty quick for a 4 banger
            GOD BLESS TEXAS
            August Landscaping
            214-779-7278
            Seb's high class.
            He'll mow your grass.
            He'll kick your ass.
            He'll piss in a glass!
              What do you have planned to knock 3 tenths off of your ET?
                35psi on that setup isn't shit.
                  Nice passes man, Didn't know Noble was up and running.
                    Foot brake??
                    Yes, with a little N2O to help with the stall.
                    Originally posted by Damnittsteve View Post
                    automatic?
                    Yes.
                    This...
                    The motor is a half filled stock block, stock crank, Aluminum rods/pistons, Stock unported head with Huge cams and supporting valvetrain. Turbo is a GT4202 non-ball bearing. With this setup on 35psi it will make right around 670whp. We have made as much as 800whp @ ~45psi before but have never been down the track with that power. We will soon though, our next race is in Houston this upcoming weekend and there is likely to be some fast Supras in the mix so we will turn it up and spray it (direct port) if we have too.
                      Don't blow the welds on the intake
                        Nice, I've wanted one of these for a while. Tires must be expensive though!!
                        Pro-Touring Build
                          and make sure to double clutch when your supposed to
                            Considering how little they wear during a burnout we prob spend less on tires than someone running RWD only. I could be wrong...
