BRR's newest project: Project Stepchild
  • #46
    scott take the spare tire hanger off its driving my nuts or put a tire on it lol!
    • #47
      Fuck off LOL it's in the works
      • #48
        lol'd
        • #49
          This is what you want under the hood or something close to it?
          • #50
            Your read my mind....would the supercharger be better for a maf conversion or is that something you could still work your magic on SD tuning?
            • #51
              guess its time for an update
              • #52
                update is in the bottom of post #3
                • #53
                  Scott- looks like progress and a heck of a project. Looking forward to getting back into a G1 soon. I'll need some electrical hookup for my garage after the first of the year.
                  • #54
                    LMK. Im supposed to go check out charles' ideas on a shop but havent had time. lucky for me he is a cool guy and will be my tuning mentor lol
                    • #55
                      Dam my ass crack makes that truck look good ! BTW , should I be creeped out that Scott is checking out my ass while i'm working ? I mean I know I am hot and all but dam !
                      Big Rooster Racing
                      • #56
                        Who the hell updates the 3rd post with new info in a 50 post thread.
                        Originally posted by Nash B.
                        • #57
                          RuSTYpNus .
                          Big Rooster Racing
                          • #58
                            Originally posted by rustypnus View Post
                            fast forward to november 2012. Wish i would have kept track of what i have done and when but for the most part here is my list of parts either on or going on the truck very soon.
                            Suspension:
                            Prothane bushing kit= - master kit red
                            new power steering gear, ball joints and tie rod ends
                            rancho gen 2 long bars
                            djm 3/4 dream beams
                            exhaust:
                            Mac 1-5/8 x 2.5" mustang aod longtube headers- ceramic coated in/out heat wrapped
                            spintech mufflers dumped
                            wheels & tires:
                            Polished stockers
                            toyo proxies 275/60/17s
                            transmission:
                            Circle d valvebody
                            derale cooling transpan
                            oem trans pan gasket
                            stayput filter clip
                            rear end:
                            31 spline eaton locker
                            frpp crush sleeve eliminator
                            unknown brand 4.56 gears
                            arp diff cap studs
                            ford racing axle girdle
                            new bearings and seals from end to end
                            engine:
                            Summit racing brand 75mm polished throttle body
                            trick flow 75mm egr delete spacer
                            ported gt40 x305 58cc aluminum heads
                            ford racing valve stem seals
                            gt40 upper port matched to throttle body-ceramic coated
                            gt40 lower port matched to heads-ceramic coated
                            accesory brackets powdercoated gloss black
                            lightning plaque powdercoated gloss black
                            coil bracket ceramic coated
                            proform 1.6 rrs
                            frpp roller conversion kit
                            frpp m-9000-l58 mass air conversion kit
                            comp cams nx264 cam
                            king race rod and main bearings
                            arp waveloc rod bolts
                            arp main cap bolts
                            new seals front to rear top to bottom
                            frpp performance top end gasket kit
                            professional products 28oz balancer
                            fms svo powerdyne bd11a supercharger kit
                            windstar dual electric fans
                            130a 3g alternator
                            electronics:
                            Moates qh tuned via the diabolical genius on akc0
                            innovate mtx-l wideband
                            ok so yesterday, saturday nov 3, 2012 was the start of my anxiety
                            can you say quakersludge??
                            nothing like a little crack to get the morning going lol
                            wish i would have taken pics of the locker and gears installed before the girdle went on....sho wuz purdy
                            as of now the rear end is put back in and only needs the brakes reinstalled and the longbars reinstalled then its finished.
                            Pulling the block out next weekend since we found all the sludge and gunk and have decided it will get new paint bearings seals and arp hardware throughout it as well as a new oil pump. We also discovered the distributor was trash....upper bearing is shot and it grinds wobbles and snags on something inside....so a new one of those will be underway as well.
                            I think we got a lot done considering i removed stripped and painted the rear end yesterday and was able to install the locker gears and new bearings and hardware as well as set up the gears and strip down the engine to the block.
                            Stay tuned
                            11/8/2012 dropped off upper and lower intake, coil bracket, and longtubes to get ceramic coated. Accessory brackets and intake plaque will be gloss black and i will paint the lighting lettering silver once he finishes...@ 475$ its a bargain
                            fixed ! Lol
                            Big Rooster Racing
                            • #59
                              Well now the original pictures are not in the post on this page? WTF I'm beginning to think you guys are screwing with me. LOL J/k Ya'll
                              • #60
                                We are . LOL
                                Big Rooster Racing
