Bike won't hold idle, dies without throttle
  • Bike won't hold idle, dies without throttle
    So my '06 R6 has been sitting a week, go out to start it and it wont fire without giving it gas, and it won't idle until I've held the throttle and kept the RPM's up for awhile. If I let off the throttle too early it just dies. If I hold it there awhile, maybe until it warms up, it idles and rides fine until I kill it, then the problem persists. I show 12 volts at the battery and 14 when its running, is this a sign of a bad battery? Or is this fuel/throttle related?
    bad gas, maybe some crud in the injectors...
    run a fresh tank of gas through it with a bit of seafoam and then see where youre at
      x2
        A bit of seafoam with the gas? I've used that stuff to clean vaccum systems on cars, same stuff right?
        It's just odd that it won't idle at first, then it seems to clear up. No dying on me while riding, just on initial startup.
          the bottle will look like this
          It will tell you how much it takes to treat the amount of gas you have in the tank or just drain the tank and put fresh gas in it but it sounds like some trash either in the line, filter, or injectors
            Will do. Hope it clears it up.
              Drain gas, fill with fresh 93. Please skip the seafoam.
                X2
                I would use seafoam for other stuff, but not fuel.
                if you just must use something, try fuel injector cleaner.....duh right
                  Throwing any codes?
                  US Politics in three words - Divide and Conquer
                    these don't have a secondary throttle valve like a kawi/suzuki do they?
                    pinto gt with wood trim
                      Download your service manual here:
                      Possible TPS issue?
                        This bike is notorious for this problem. Mine does the exact same damn thing and after hours on forums I can't pinpoint what is exactly wrong. If it's under warranty that may be your best bet. If you do find out what it is please post up. I ran sea foam and it does not help. Changed plugs etc etc.
                          The only other culprit I can think of would be the TPS sensor.
