We are hiring for CNC Machinist position. PM me for link. It is in Saginaw, TX at a Contract Manufacturing Fabrication Company...
CNC Machinist
Responsibility Description:
• CNC Mill operators are responsible for jobs requiring a step at this work center. This includes, but is not limited to ensuring quality material is used, correct metal type and thickness is applied to the job, and ensure cut quality meets Anchor’s standard.
• CNC Mill operators report to the Precision Supervisor on duty.
Specific Job Responsibilities:
• Locate and ensure correct material is delivered to his/her work center
• Ensure machine is working properly, specifically that consumables are in good working condition
• Ensure appropriate program is delivered, or entered, to their work station
• Ensure that the correct tooling, feed, and speed combination is applied for the corresponding cut
• Accurately project completion of work orders at his/her work center
• Completes assignments on-time and correctly the first time
• Ensure jobs are staged correctly after completion
• Continually maintain a clean working environment
• Notify Precision Supervisor when tooling is needed
• Experience with CNC Vertical 3-Axis Mill
• Familiar with setting up tooling on the mills
• Conversational programming experience preferred
Qualifications:
• Must be able to read and understand prints
• Must be able to read and understand measuring device
• Prior work experience with CNC milling equipment preferable
• Formal education is not required
Environment/Physical Requirements
This position is carried out in a fabrication shop environment and as such has the following physical work requirements:
• Must be able to lift 100lbs.
• Position requires ability to stand for prolonged periods of time.
• Position may require bending, kneeling, and stooping.
• Exposed to shop elements such as noise, dust, odors and chemicals
Steel toe boots required
Temp-To-Hire Opportunity
$12 - $14/hr
Send detailed work history
CNC Machinist
Qualifications:
$12 - $14/hr
