Ok, I am about to run my power for my air compressor. I am putting it on its own dedicated breaker. My problem is that for the other 2 circuits I have installed I was able to get into the attic and stab the wire through the hole where all the other wires come up into the attic from the breaker box. The last one I did it was a real bitch trying to get the wire through and it was only 14/2 romex. I know for a fact that the 10/3 cable that I have (at least 3/4" diameter) to use will not fit through any holes. The slope of the roof comes down on that part of the attic and it is not possible to get a drill into the attic to make a new hole. So what do you guys do to get the wire into the breaker box?
electricians I need help
Originally posted by inline 6 View PostOn the attic side I could probly hit it at about a 30 degree angle and that would shoot me into the brick before I cleared both 2x4's.
im an electrician so if you need any more help feel free to text me at 2148017467. If your local i might be able to swing by and help you out
Arlington BTW
Originally posted by STANGGT40 View Postif the panel is in the garage, just cut a small piece of sheetrock (from stud to stud), at the top of the wall above the panel, drill the hole, run the wire, and screw the piece of sheetrock back on.
Originally posted by lo3oz View PostThey make a flexible drill bit / bit acceptor.. use that if you can get the paddle bit in there perpendicular but don't have the space for the whole drill.
i think flexbit makes them, not sure on cost though.--carlos
Other than the way I mentioned, cutting the flap would be the easiest way to do it. Those flex bits work but not really ideal for the area your working it. The header has two 2x4s and your paddle bit is going to have to be at least that long. You will still have clearance issues. Only other way is to come out under the eve in PVC and penetrate the back of the panel....... That's if your wanting it to look professionally installed.
By then your best bet is to pay me to come do it lol
The header is 2, 2x4's like said and by the time you get a bit in there, there just is not enough room and you are already stretched out laying down trying to get into this pinched down area so you couldnt get any type of force down on the bit anyways not to mention you are laying accross one 2x with your leg out over the next one trying to balance yourself to keep from falling through into the garage.... you are starting to see the picture......
Originally posted by inline 6 View PostThe header is 2, 2x4's like said and by the time you get a bit in there, there just is not enough room and you are already stretched out laying down trying to get into this pinched down area so you couldnt get any type of force down on the bit anyways not to mention you are laying accross one 2x with your leg out over the next one trying to balance yourself to keep from falling through into the garage.... you are starting to see the picture......
