My clothes washer isn't draining like it used to, after the spin cycle. When it's 'done' with the entire cycle, the clothes are still sopping wet. I know there is no obstruction in the house plumbing. There could be some blockage in the flex tube that comes off the washer drain, to the house drain. But other than that, or a loose/worn belt, what else might cause this? I know the pump itself could be the issue, but I want to start with the simple cheaper stuff first and take it from there.
Drain blockage, belt, pump. Anything else that I may be missing?
