The door is not closing right, I went outside and noticed the gap at the top is wider, gets less as you get closer to the bottom (trying to word this so it is not sexual!).
I tried all the screws, all are tight. It is scraping the opposite side whne it closes, so over the last year, it has actually worn down a part where the screw head hits the frame on that opposite side.
You can see here the wider gap at the top
Opposite side where the door gets "stuck" when closing it, there is a screw hitting the edge of the frame (inside the doors edge).
