The master bathroom doors seem to have a slight issue, it is the double doors that have a little ball bearing like thing on top, and sort of click into a plate on the top of the doorway frame. The handles do not turn, it just pushes and pulls closed/open.
There is one door, that even tho it seems aligned properly with the other (not drooping when they meet), it will not hit that plate and stay closed.
I tired loosening all the hinges, pulled up on the handle and tightened the top hinge first, then middle, then bottom, but not enough difference. It barley touches that plate, but not enough to keep the door from swinging open a little.
Other than removing the plate, and using a couple washers to lower it, any suggestions on how to fix it? I'll try to post a pic in a bit.
Rather than post a pic, I googled one, and think I found the solution. It is called a ball catch
