I have a 220v outlet in my garage. It's marked 15 amps.
The old lady bought a tanning bed, and the plug is a different shape than the outlet, and it's marked 30 amp.
The switch at the breaker box is marked 30 amp. In fact, it's two actual switches that move together, instead of just one switch for my 110 circuits.
Logic tells me if the bed pulls 30 amps, then it's not good to plug it into a receptacle marked 15 amps. Besides, the two plugs are not the same configuration, anyway. I can cut the power at the breaker box and install a different receptacle, if it's that easy of a fix, but I don't want to screw around if it's going to be too much more difficult than that.
Also, it looks like I'll need about an 18' extension cable for this, based on where I can put the bed. Are there any issues with that long of a run, as long as I buy a quality cable?
Any advice would be greatly appreciated. I live in a very remote area, and getting an electrician out here is almost impossible, and will cost a fortune.
Thanks!
Thanks!
