I'm not an A/V guy (so have no input on the equipment...configurations...etc) but deal with a ton of different cable types in my job. If at all possible, trim those cables to custom lengths and clean them up.
Draped and overall cluttered cables have a habit of doing 3 things.
1. Get tangled and create a disaster later. (Either way, label both ends of any/all cables and create a cable map)
2. Reduce airflow for cooling since they tend to block either the inlet or outlet of anything designed for this purpose.
3. Prematurely fail since the ends (whatever it maybe, my most experience is with BNC and RJ-45)) are supporting the cable weight when not properly trimmed and secured. Sometimes this can be not a full failure and create glitches and other things that are a bitch to troubleshoot.
Cabling is a PITA, but it has to be done right or it can introduce problems and generally makes the job cleaner in the end.
You're absolutely right.
90% of the cables had nothing to do with me. I coiled and bound everything that wasn't part of this project, and left it better than I found it.
However, I did isolate, trim, and label everything that I had to deal with. There are two 6' HDMI cables for a future project, but that's the longest cables I left.
All of their components are wifi. The Denon app recognizes each component and adds the correct remote. Pretty simple, and it works. Repeaters are old school.
