Pool help
  • Pool help
    The previous owners left us no directions with the pool and no markings are on the valves. Anyone have any ideas on where to turn for vacuum and backwash? The valve on the left cuts off water if turned 180 and the right will change pressure in the filter but that's all I've figured out
    07 f250-family truckster
    08 Denali -baby hauler
    52 f1-rust bucket
    05 Jeep tj. Buggy
    livin the double-wide dream
    The t-handle in the back should be for back wash. But you will have to add d.e. if its a d.e. filter.
      The vacumm should have a switch at the elec. Box.
      must be a big ass pool having two drain valves
        De? It's a salt system of that matters
        52 f1-rust bucket
        05 Jeep tj. Buggy
          De is just earth material the you put into the filter to help the filter filter better.
            The valve on the left is the suction side and it is wide open at the moment. The valve on the right is the water returning to the pool. To tell you what it does I would need to see your pool. What part of town are you in? If you are in my service area I will come by and mark the valves for you.
              Honestly, go to Leslie's and make friends with them. They are too expensive in my book but I used them for the first few weeks to help get to know my pool. Now that I have a good understanding, I buy most chemicals online but if a new question pops up, I can take pics up to them. The one here in grapevine has staff moderately knowledgable.
                I'm in watauga
                52 f1-rust bucket
                05 Jeep tj. Buggy
                  +2. I see it after looking at the piping locations.
                    Where the best deal on DE?
                    2015 F250 Platinum
                      Originally posted by whitetrash View Post
                      I'm in watauga
                      I never get out that way.
                      How many skimmers does your pool have? Can you see the hole for the pipe in the skimmer when you remove the basket or is the something in the way? It there a fitting in the wall of the pool that has a spring loaded door covering the opening? Is there a water feature? How about a pool cleaner? Can you post a pic of the pool?
                        Pool has 1 skimmer 2 drains. No flapper in the skimmer. When I remove the basket it has 2 holes in the bottom
                        Only pic I have currently but can get more this afternoon
                        52 f1-rust bucket
                        05 Jeep tj. Buggy
                          How deep is that pool?
                            5.5-6 depending on water level
                            52 f1-rust bucket
                            05 Jeep tj. Buggy
                              I can swing by on my way home one day and teach u everything u need to know....that filter should also be taken apart, cleaned and inspected for any damaged grids...
