Well... I have wanted to do a DIY sub for a long time. AVS forum has great info. Its actually overwhelming the amount of info, line graphs, technical terms, etc. Luckily there are some great people who love to help and others document their builds for people like me who have no clue.
So Im building dual slot ported 18" subs.
The parts
(2) Stereo Integrity 18" D4 subs
Inuke 3000dsp amp
(2) custom built boxes around the "Marty" platform. This particular one is called the "Johnnysub" based on the dimensions. 25.5"W x 32"H x 24"D
They should tune out to about 18.5hz. About 2200 watts total. 116db at 20hz. It has a very nice flat curve.
I didnt really get pictures of assembling but its pretty easy. These builds are based off simple plywood dimensions to maximize wood. Two boxes uses 3 sheets of MDF. They should weight about 150lbs with the 40lb subs in them.
Tomorrow Im going to close them up, add a little more foam and drill for the subwoofer mounting hardware. Im not sure on the finish (have laminate samples coming in but not sure if it can do a 3/4" radius bend..if not it will be veneered).
Here is a picture of the current SVS PB12-NSD which I though has been good. Everyone that has heard it thinks its loud and shakes the house. The new setup will kill it.
And here is one of the to new subs in comparison (I dont drink DP so Diet Mt Dew can substitute).
The parts
Inuke 3000dsp amp
