no power in garage after storm.
  • no power in garage after storm.
    Garage flooded... The garage is completely dead. Fuse box doesn't show any tripped fuses. I turned the garage off and on. Didn't work. There is a small metal cover thing that was under the fuse box with two red lights lit up. Need help. Thx. Or if any of y'all are electricians, come on over.
    The two-three outlets don't work I should say. The garage door works fine.
      There's a GFCI that is tripped, not a breaker. Check the receptacles to see if any have the "trip/test" buttons.
      My garage had one on an outlet that could be tripped by any of the other ones in the garage as well.
        Uh OK. Lol. I'll give it a look, sorry Idk what that is. I assume its on the actual outlet.?
        If it fixed it, thanks in advance!
          My garage gfci was in the downstairs half bath, so check weird places. You're looking for the outlets with test and reset buttons on it
              Sounds like a total loss, I'll give you $5000.
                gfci it is... could be anywhere in the house. Most electricians make zero sense on how they wire a house.
