I'm about to return this thing since i've tried multiple combinations and still can't figure out where the red wire goes anyone have any insight? hot wire capped off currently on pics.
For single pole applications, wire the sensor switch according to wiring diagram #1 using the wire nuts provided.
1. The sensor black wire will connect to the hot wire (black) in the wallbox.
2. The sensor red wire will connect to the wire which goes to the light fixture.
3. The sensor white wire will connect to the neutral wire (white) in the wallbox.
4. The sensor blue wire is not used and should be capped off with a wire nut.
5. The sensor green wire will connect to the ground wire in the wallbox.
6. Install the sensor loosely using the mounting screws provided.
7. Apply power temporarily and verify that the sensor works by pushing the ON/OFF button to verify the lights turn on
and off. If the lights do not work, then turn off the power and swap the connections on the sensor black and red wires
8. Apply power again and verify that the sensor works by pushing the ON/OFF button to verify the lights turn on and off
