My garage has two small doors but I'd like to switch it to one large door. I know this can be done. Does anyone here have experience with this or know of a contractor in the area (Richardson) that can do something like this? Any ideas how much it might cost?
Garage Door - Going from 2 to 1
Originally posted by Torinoman View PostMy garage has two small doors but I'd like to switch it to one large door. I know this can be done. Does anyone here have experience with this or know of a contractor in the area (Richardson) that can do something like this? Any ideas how much it might cost?Originally posted by LeahBest balls I've had in my mouth in a while.
Good luck...Like he said, you will probably have to switch over to a LVL beam. One story house will be cheaper but if you have a 2nd story above it, you should get an engineer involved. You may want to open up the drywall and see if they used a single beam or if the middle post between the garage doors is a place holder or truly the support stud
Originally posted by talisman View Postyellowstang got it done to his old house and it wasn't a big deal."If I asked people what they wanted, they would have said faster horses." - Henry Ford
I should mention its a detached garage, there is nothing above it either. Just a freestanding garage behind my house.
It doesn't seem like it should be a huge deal but I just don't know how to start this project or who would do this kind of work.1971 Ford Torino - Time to go bigger and better.
Originally posted by lowthreeohz View Post^ thats reassuring because I'm waiting for a bid to remove ~8' of load bearing wall between my kitchen and living.
OP being freestanding and nothing above I bet it will be fairly simple.
If they dont get an engineer or architect involved...Id pass. There are rules of thumb line "inch per foot" but read up on your local building codes. The inch per foot rule is only for single story with a lower pitched shingle or metal roof (something like that). My cousin is an architect and he said the inch per foot rule applied to my house (single story) though it wouldnt hurt to go bigger. We opened up 12' of load bearing down the center of the house with (2) 2x12s and a double existing top plate. He said if I wanted it flush with the ceiling, I needed to find an engineer.
Also, there is a program called 'Forte' that is an engineering software you can download online (from one of the LVL manufacturers) that will calculate the load.
To the OP... check out Southern Pine's header tables if you open your drywall up to see if the center column is load bearing:
I think DFW building code wants 20psf snow load (dont quote me on that)
Originally posted by 8mpg View Posttotally different animal. Is it a one story or two? Are you willing to have a header drop down or do you want it flush with the ceiling? What pitch is your roof and what roofing material? Which way to the trusses run? Is this the center of the house or off to a side?
Our place is 2 story, wall coming out is near the middle. The existing framework is exposed ie not hidden in ceiling so I'm fine with the lvl one sharing the same form. Actually waiting for the engineer to come out next week and do the math, just hoping it's within my budget.
Originally posted by lowthreeohz View PostYou're right, I was thinking very simplisticly.
