Is there anyway to get the color back on faded bricks? This house had no gutters and I don't know if that contributes but there's area where the bottom 3 layers are faded.
I used my little 1200 psi washer and it didn't seem to make a difference.
Think I need a real mans power washer?
Try again with the 1200 set to the thinnest spray pattern and see if it "cleans" a mark off it, like trying to make a line across it or something. I'm thinking the 1200 psi is not enough, at least on a pattern that is kind of wide to clean the area. Also, did you add anything other than water when trying?
