Cut all that shit off and sweat on a new one. There's plenty of exposed copper, should be easy.
Outside faucet replacement
That little ball valve goes to my pond. The other before I removed it went out to the middle of the back yard before I put in the slab. I flipped it one day and saw the gusher mid yard. Thought I would just plug it off and use it for my auto fill. Yeah not so much.Whos your Daddy?
Fuck it, I only had to get the fire extinguisher once. Shark bite fittings rule! I hit the thing with the torch so long I ended up firing up the insulation. Finally I said screw it and busted out the saw. That T fitting looked soldered but I swear when I cut it, it was solid. Anyways, cleaned it up and slapped a shark bite on. No drips and I love the new faucet. Now I need to clean up the wall and paint it. We won't talk about the front one. I am just glad it went back together and doesn't leak. I broke off the screw that holds the washer on the end but it wasn't sealing anyways. My theory on similar was way off also.
The old front ones innards I now need to replace.
