I have a Hayward H400IDPL pool heater that worked briefly. We changed out the Propane tank and now it simply flashes A0 on the small control panel. Any ideas?
Pool heater issues.... Anyone?
Originally posted by Taya Kyle, American GunThere comes a time when honest debate, serious diplomatic efforts, and logical arguments have been exhausted and only men and women willing to take up arms against evil will suffice to save the freedom of a nation or continent.Tags: None
The inducer motor vacuum switch is not closing, there should be a small blower that pulls fresh air through the burner assembly, you should either be able to hear it running, or feel air blowing out of the exhaust if its functioning. If that checks out, either the pressure switch is bad, you have a vacuum line leaking, or there's an obstruction in the hose or pick up orifice. If you find it was a hose or stuck switch, remember to cycle the power or it will stay locked out on that fault. Good luck
