Toilet not filling with water
  • Toilet not filling with water
    i had a toilet that was loose so I had it pulled up and a new flange put in. now the tank wont fill with water. It stays about 2 inches deep. I filled a bucket with water and poured it in but it drains out and goes back to the about 2 inches level.
    Any ideas?
    Thanks in advance
    Is the flapper not sealing? They are cheap, might start with that. Also, you replaced the wax seal when you put the toilet back in, yes?
    -Henry David Thoreau
      yeah it was replaced
        found the problem
          Was it the Obama? Usually is.
