Need a 12x12 deck built.
Originally posted by talisman View PostGas log install turned into a fiasco. Found out for some reason a previous owner cut and capped the line to the fireplace for god knows what reason. Now I've got to get that fixed. Not a big deal, just annoying. My contractor had to go dig around in the attic for them and find out what was going on.
They made good progress on the patio cover and they're still working.
It has really darkened the inside of my house, which I like, even though it only goes above one window. When I had the solar screens installed I went with 80% and should have gone 90, but I think this will correct a lot of the light. I'm gonna be a pale mofo.
Didn't I tell you to get 90 on the west windowsBARBIE LOVES BULLITT991 3.17.07
I'm a Barbie girl...In my Barbie world...
PROUD OWNER: '04 AZURE BLUE MACH 1
Grass is low priority with people stomping all over everything. Next year I'll, ahem, spread some seed around. This year I planted trees so they can start taking off. A lime, a Dogwood, 2 Oaks, and 2 Windmill Palms.
I do need some opinions. If this was y'alls house, where would you position the tub? Initially I was going to put it in the corner of the big open area that was just built. Now I'm thinking about putting it up against the walled side, both for privacy and for giving the seating airflow on the new open side. Thoughts?
I bought this set up for seating. It all comes apart and can be arranged any way you could imagine. It should be here today or by Thursday. Sitting in Fed Exes Fort Worth Warehouse now.
Originally posted by talisman View PostNow I'm thinking about putting it up against the walled side, both for privacy and for giving the seating airflow on the new open side.
i'd prolly go this route.
god bless.It is easier to build strong children than to repair broken men -Frederick Douglass
Up against the wall it is. Have an electrician coming out Monday to wire it up, will have to fill and dump it once, and hopefully next week it will be good to go. Patio furniture is here. I've thoroughly hurt myself in several different ways putting it together, so I'm trying to slow that down. Once it's done I'll put up pictures of the whole set up. Hoping this tub has a big impact on my back problems.
