I need to build a retaining wall about 3 blocks high at a sloping fence line that is eroding. What is the best way to do drainage. I was thinking a French drain the length of the fence line, exiting at each end.
Retaining wall and erosion.
Are you building the wall and then back filling the yard? The way the walls are built in our subdivision is with pvc weep "holes". Excess water from the yard will roll off of the back of the wall. The purpose of the PVC is to prevent a pressure build up from excess moisture blowing the wall out
Sent from my SAMSUNG-SGH-I727 using Tapatalk 2Originally posted by LeahBest balls I've had in my mouth in a while.
