We just purchased a home, and although it is functional...we want to upgrade a few areas.
The master bathroom has a huge empty space, 4x4', on the entry end of the shower. It looks like either the builder couldn't budget a larger shower, or couldn't budget a larger tub...and ended up with an empty space for future upgrades.
I've been seeing a lot of showers with a half wall, glass on top, and then just a small cased opening which allows entry into the shower without any door or curtain. I've also seen a few where there is a half wall without glass.
The entry, in our case, could be 4'+ away from the water source, so splashing would be a minimal concern. A small lip could be built off the floor at the entry to prevent runoff, but the floor would obviously be made to drain.
I'm considering removing the existing composite shower, and making a tile/stone one with this doorless setup. I'm looking for opinions on this type of setup, if anyone has one.
I'd like a little more room in the shower, a little less glass door to clean, an updated look, and good use of the wasted space.
And, yes, I really just want to put a big banging bench in there!
Input?
Something similar to these...
Thanks in advance
Input?
Thanks in advance
