HVAC guys, I need some help. Problem with indoor blower motor.
  • HVAC guys, I need some help. Problem with indoor blower motor.
    It's a Ruud Upflow furnace unit model UGDG-075AMGR. The original problem is that the indoor blower motor won't shut off.
    So far I've:
    - Replaced batteries in digital programmable thermostat.
    - Verified that the fan ALWAYS ON function on the thermostat is NOT engaged
    - Removed thermostat & fan still runs
    - Made sure that the thermostat is telling the fan to shut off
    - Replaced the limit switch with a new Protech 47-25349-02 replacement
    Then I happened to see a small spark flash through the small vent hole in one of the relays. From what I can tell it's the relay that controls the fan. So I then bought the Protech Board since the relays aren't removeable.
    The board in there now is a Honeywell ST9101A-1014. When I went to get another one I was told that Rheem has said that the Protech 62-24084-82 board is the one I should use to replace it. I bought the board but I want to make sure I hook up the wiring correct. The paperwork that came with the Protech board is basically useless.
    I tried to attach the pics but the site is not wanting them. I do have the pics in a thread I posted up on a DIY forum here. http://www.diychatroom.com/f17/repla...inside-163364/
    As I posted over there, after sitting here and really looking it all over I think these are the proper hookups from the old to the new board.
    On the Honeywell I have wires connected at:
    Heat
    Cool
    M1
    M2
    N - two of them
    S
    C
    So this is what I'm thinking.
    Honeywell Protech
    Heat ----> Heat
    Cool -----> Cool
    M1 -----> M1
    M2 -----> M2
    N -----> Neutrals
    S ----- SEC
    C ------> COM
    X ------> XMFR at the L1 location
    So this is where I'm at right now. Any input is much appreciated.
