So I finally gave in and turned the heat on at my house 2 days ago. Well I say "turned on" like it was easy. I have a digital thermostat and it had no heat option.
After going into technician mode, I was able to tell it to go to 3h,2c mode (three heat, two cold mode)
Then "heat" was available. Kicked on the outside unit and voila, heat!
Tried to turn heat on again last night, only emergency heat came on. Outside unit stayed off. Tried to enter tech mode to turn it to 2h,2c, option no longer exists.
Tried to turn A/C on, outside unit wouldn't turn on, but it was 52*, so that may have prevented the compressor from kicking on.
I know jack about Heat Pumps. Mine works/worked...is there some sort of trick to them?
