How do you know if a wall is load bearing if you do not have blueprints?
Load bearing wall
haha besides that way. It's a wall in our bathroom upstairs that has the shower head on it. I was thinking of knocking it down, moving the head to the other side of the shower area, removign the tub and just having a shower since our master bath is tiny, but I don't know if this wall is load bearing or notOriginally posted by red95gts View PostKnock it down and see if the house collapses?
This is the easiest way to be sure, if you have good attic access above it. Also take a good look around and see what else might bear the load. Typically, "plumbed" walls are 2x6 walls, and a lot are exterior also, which means they are load bearing.Originally posted by BlueCoupeRedVert View PostLook in the attic. If you see any boards going from the attic floor to the roof rafters... where its hits attic floor(the ceiling) the wall below it is "bearring" the load or the roof.
Hey! There is another improvement you can do!
My Dad has an older house and made an entry from the garage to the attic. Just uses a ladder and he finagled a door...etc...etc. 5x larger than the entry originally put in.Originally posted by MR EDDU defend him who use's racial slurs like hes drinking water.
2 story house. the one in the garage is normal size, however the one to get to the upstairs attic is about shoulder widthOriginally posted by ceyko View PostHey! There is another improvement you can do!
