Garage Door Repair
    Originally posted by Dacotua View Post
    I would want it fixed ASAP. Usually a car is trapped because of it.
    Door companies know this and charge a lot for it. I do this stuff on the side and I dont pull any BS. I fix just what is broke. And since this is a side thing for me I do it usually after 7pm at night
    Do you install openers? I have a 8x18 and a 12x12 thats in need.
    2015 F250 Platinum
      I have a problem when opening my door. It will only open from the main button. Then when I leave the outside keypad doesn't work nor does my car opener. So I have to go inside and hit the main button to close it. But when I come home and about to get into the driveway the car garage opener works.... some bullshit if you ask me!
        I can install anything dealing with the doors/openers
          Check your batteries in the remotes. Then get a pencil and use it to coil your openers antenna wire.
          Never hurts to check to make sure your light eyes are not blocked
            Coil the antenna? I've never heard that tip.
