I'm in the market for a new compressor to replace my oil-less 30 gal one. It's OKAY, but I'm looking at a single stage/oil lubed for...
1. A little more quiet operation
2. Faster re-fill
3. Little better performance
Generally I use air ratchets the most, air wrenches, cut off tool, air chisel and I'd like to be able to use air grinders, sanders and paint things with air as well.
I have 220 in my shop but I also need the compressor in the garage. I considered a really long hose, but long story short - I'm staying 110. I'm checking out these two and was curious if anyone had any experience or input with them.
Kobalt 1.6 HP 30-Gallon 155 PSI Electric Air Compressor
- I like this one because of the 30 gallon tank and it's similar spec to the IR below. They both have acceptable warranties (especially when compared to the Harbor Freight version).
Ingersoll Rand 2 HP 20-Gallon 135 PSI Electric Air Compressor
-This one seems to have mildly better specifications and is a pretty good name in the market. I don't care for the 20 gallon tank, but in theory - for a home user and its overall performance it may not be an issue. A couple of buddies bought this one over the Kobalt. Generally speaking the Kobalt is less cost, a similar performance with a bigger tank. So, I'm trying to figure out what I'm missing at this point. It's a very nice compressor, but for the reasons listed above I'm a little confused. As dumb as it is, I do like that it's a lighter color paint for when I have it out in the sun.
Edit: Request this not be moved to the Garage or something. Looking more for input from a DIY'er at home as opposed to professional shop input. They need the high-end expensive stuff, that just is not realistic for my budget/needs.
2. Faster re-fill
