I generally get a PM every two weeks or so from forum members asking about garage door repairs.
Do NOT try to fix your own springs unless you have winding bars. I believe that you have the ability to repace them but without the proper tools you can get hurt badly.
Ive replaced many forum users springs, repaired doors, replaced doors, operators etc. I generally do this on my spare time and after 7pm. Depending how far away you are from me.
Dont fall for gimmics, like you see on roadside ads stating a 60 "tuneup" on your garage door.
Most springs are rated for 10,000 cycles. They last for 8-10 years.
Unlike what you would think ONE SPRING is better than two springs. Cause if one breaks, your replacing both. A single spring is made of a thicker gauge wire, than a double spring. I seen single springs last about 20% longer.
IF YOU HAVE A SPRING BREAK ON YOU, do not operate the door. You can damage the operator. Throw cables, damage the door, etc. Also dont think you can lift the door on your own, unless you can bench about 300 pounds.
Any way if you have questions on garage door stuff feel free to send me a PM.
4 door
