Heater in House not Working?
  • Heater in House not Working?
    I had it set for 68 degrees last night and woke up this morning and it was 58 in the house! It was working just a week or two ago when we had it on. Only thing recently is that my thermostat showed low battery and I changed them a few days ago, would this cause any issues?
    Do you know if you have a heat pump? Try your emergency heat setting. If the heat comes on there may be an issue with your heat pump. Do not use the emergency heat for long as it is straight electric and will be a killer electric bill. Hopefully it is just something with your thermostat.
      I'm having the same issue.....what happened? Do we have a hookup on here for an HVAC guy?
      BEWARE OF PEREZ TRANSPORT LLC
      BEWARE OF EXOTIC TRANSPORT
      Fernando Perez
      Alijandra Perez
      Mesquite, Texas
      214-680-1415
        Is it gas? Check the pilot light?
          Electric. A breaker was off, got it going now.
            Your avatar is EPIC!!!!!!!!
            Originally posted by Nash B.
              pilot light is good. no breaker tripped.
              Fernando Perez
              Alijandra Perez
              Mesquite, Texas
              214-680-1415
                There could also be a breaker on the blower unit in the attic. Is it not blowing or not heating up? Could be the ignitor if it's gas, too. They're electronic.
                  Does it even try to come on? Have someone turn it on while you're up there and see if anything at all happens. A simple issue I had last year is that a rubber hose became disconnected between the plenum and a positive pressure switch. Gas comes on, fan starts blowing, but if the switch isn't made the unit doesn't think the fan is working and shuts down.
                    thanks to junk racing ie H and H Heating and Air. Sent Jamey out to my house last night at 7:00....found out it was the blower motor....less than 400 bux installed and I will be back in business tonight. Thanks for the great service guys!!!!!
                    Fernando Perez
                    Alijandra Perez
                    Mesquite, Texas
                    214-680-1415
                      no problem
                      81 LX
                      82 GT
