best blackfriday surround sound systems?
  • best blackfriday surround sound systems?
    I'm in need of a home theater/surround system.
    Has anyone seen any good deals for black Friday?
    It doesn't need to be top of the line but id prefer wirelss. I plan to use it with a PS3 and a digital cable box.
    Any help is appreciated.
    SQ
    Check bfads.Net, I saw some klipche home speakers on bestbuys ad.
    Sent from my Nexus One using Tapatalk
      HTIB systems are entry level and have sub-mediocre subs. Also, they use very low impedence (ohms) speakers, that will not be compatible with most AVRs, if you so chose to upgrade and keep the HTIB speakers. If your budget allows, I would build a Home Theater system component by component. However, if you're looking for something that's complete and easy to set up, then HTIB is your answer. In that case, I would recommend Dayton, Energy, Definitive, or Onkyo. I've listened to several Sony HTIB systems in a very affordable price range and they were pathetic in all regards.
