Someone school me as to why people look down on plasma tvs....
what is wrong with a plasma??
I personally see nothing wrong with a plasma. But, LED and LCD are thinner, lighter and produce less heat. They also have no glare when watching from a room with a lot of windows, where a plasma will. There isn't a thing wrong with a plasma, it's just the changing of the times. Technology is progressing.
Nick
Originally posted by Nick Chapman View PostI personally see nothing wrong with a plasma. But, LED and LCD are thinner, lighter and produce less heat. They also have no glare when watching from a room with a lot of windows, where a plasma will. There isn't a thing wrong with a plasma, it's just the changing of the times. Technology is progressing.
Nick
Everybody has different tastes in this world, so just because Me EDDDDDDDDD wouldn't like a plasma, doesn't mean you won't
Personally, I think they have some of the best pictures(aside from blacks). But like I said, everyone has different tastes. If it looks good to you, and it's cheap, then go for it! If I'm not mistaken, their life expectancy is 60,000 hours. So that's a good bit of TV watchingI'm not real sure about the burn in issues anymore. I really haven't been paying too much attention to the plasmas in quite some time. I upgraded my living room TV from a 42" plasma, to a 55" LED. And I went the LED route simply for weight issues. The TV in the living room is mounted above the fire place, in brick. So I couldn't go too much larger with a plasma due to their weight.
Nick
We have plasmas, LCDs, and DLPs in my house, and the plasmas have the best picture. They do put off a lot of heat. It's noticeable when you walk within a few feet of it. Glare is an issue at times. And even though they aren't supposed to get burn-in anymore, both of mine have visible lines on the sides from where some shows weren't in widescreen format. I think it's an issue that will never be 100% fixed with plasmas.
Originally posted by jluv View PostWe have plasmas, LCDs, and DLPs in my house, and the plasmas have the best picture. They do put off a lot of heat. It's noticeable when you walk within a few feet of it. Glare is an issue at times. And even though they aren't supposed to get burn-in anymore, both of mine have visible lines on the sides from where some shows weren't in widescreen format. I think it's an issue that will never be 100% fixed with plasmas.
I have zero problems with my plasma and do not regret buying it.
I would not buy another one though at least for aux TVs. LCD or LED. Why? Heat.
Now, when the time comes around to buy another 58 or bigger TV - I'll consider a plasma due to their picture quality. However, I'm guessing LED/LCD TVs are going to be decent as well.
Literally, my plasma puts out 110-120F over most of the screen. In the Texas summer that sucks. That's not including what will be bleeding off from the back vents and such.Originally posted by MR EDDU defend him who use's racial slurs like hes drinking water.
I have a plasma in the LR and a LCD in the BR. I personally like the plasma better. I've only experienced burn-in one time when the GF left the Netflix mainpage up for a couple of hours. My tv has a "screen-wipe" type process that is supposed to remove burn-in. I ran it for about 3 minutes and it looks fine again.
I can comment on the burn in as I have run into this a few times with mine. I will spare the long story leading up to it and just give details. I have had 3 instances of burn in (left on a fixed image for an hour or two) that was on my screen for about a day. It was gone after a day or two of tv watching and can't tell it was even there.
I am not saying it won't happen but the few times it was burned in it was gone within a day. After everything that has happened I am pretty confident I won;t have any issues. I have played games, left it on guide and everything that ha sbeen bad for these tv's in the past with no issues.Originally posted by Cmarsh93zDon't Fuck with DFWmustangs...the most powerfull gang I have ever been a member of.
