I just bought a few boxes and tools, but I dont have any time to do the installation of the dynamat. Do audio shops do the installation of this stuff? I've done it before on a few cars because I'm cheap but it is tedious plus I am slow and don't know best practices so I'm sure someone could do it much better than I can, and now that I can afford it, I'd rather pay someone else to do it. I have a 2006 300C and live on the east side of town, any recommendations?
sounddeadening installation
I don't know if this is even a thing, but have you talked to a body shop? They deal with all the exact same crap, (taking out carpet and seats and door panels and shit) and they just might do it for a lot cheaper. I'd give a few of them a call before I paid the uber prices that the audio shops would want for that.WH
Labor is $75/hr. Sound deadener installation usually averages out to $45/4sqft sheet when doing multiple sheets. Doing one sheet per door or one sheet under the carpet will be higher because I can not average out the removal/reinstallation of door panels, carpet, etc. Additional grief is extra. Removing the console may be extra. Some people online make sheet metal panels, ABS panels, fiberglass panels, etc. to cover large holes in the inner door skin. Quotes on such panels will be on case by case basis.
Sound deadener installation is time consuming hard work but the results are worth it IMO.
Sound deadener Showdown is supposedly the best, but they're also the most expensive. If you do everything you're looking at thousands of dollars worth of sound deadening just in one vehicle.
There are different materials for different purposes but the Stinger product is the best value IMO. Butyl rubber and thicker aluminum than most. Their carpet pad is excellent too. Dynamat and hushmat are really expensive in comparison. The most a customer has ever spent with me is $2500 for all parts and labor to gut an F250, cover every square inch with material including inner and outer door skins, under hood plus hood liner, as well as carpet pad. It was amazing.
It always boggles my mind that people only use the stick on "dynamat" style and never use the rubber/foam/ vinyl mats. I layered my 66 from toe board to package tray in Second Skin luxury liner (old style) and it was night and day difference even after a complete covering of rattle deadener.
Originally posted by EW View Post$2500 for all parts and labor to gut an F250, cover every square inch with material including inner and outer door skins, under hood plus hood liner, as well as carpet pad. It was amazing.
Originally posted by Z06killinsbf View PostIt always boggles my mind that people only use the stick on "dynamat" style and never use the rubber/foam/ vinyl mats.
http://store.secondskinaudio.com/lux...-ft-full-roll/
How did this affect carpet fitment, around the edges where the carpet meets the trim and trim panels? In my mind, you've got to be looking at a half an inch of new thickness added to the floor.WH
