I know this is probably rethorical, but in a 5.1 track is there a way on the amp to force 7.1? basically split the side surround signal between the sides and backs? Or even duplicate the side to the back channels?
Receiver gurus... 7.1?
Originally posted by STROKD View PostI know this is probably rethorical, but in a 5.1 track is there a way on the amp to force 7.1? basically split the side surround signal between the sides and backs? Or even duplicate the side to the back channels?
Originally posted by STROKD View PostIt does, but pl2x doesn't sound as good as just DD 5.1... I was more thinkin a way to make DD 5 play all 7... Without the media sent out in 7...
Originally posted by jluv View PostIt just plays the 2 channels of audio on 4 speakers instead of 2, accomplishing exactly what you described. Not sure why it doesn't sound good to you or what other way you could get there. Sounds good to me!
1. That's what Pro Logic IIx processing is for, which is standard bill of fare on modern receivers sans some entry level gear.
2. All of my new Panasonic Blu-ray players have a feature called 7.1ch Audio Reformatting. When enabled, all native lossy or lossless 5.1/6.1 channel soundtracks get formatted to 7.1 then sent to receiver via HDMI. I assume this feature is available with other brands as well.
Originally posted by 3.90x3.62 View Post1. That's what Pro Logic IIx processing is for, which is standard bill of fare on modern receivers sans some entry level gear.
