Ford Racing M-5251-M8 Mustang Resonator Delete X-Pipe GT 2015
This is Ford Racing's stainless steel resonator delete x-pipe fitting all 2015 GT Mustangs. One of the most common complains about the 2015 Mustang GT is the factory resonator on the exhaust, its both heavy and restrictive. If you want to eliminate the resonator but don't want to replace the entire exhaust system Ford Racing now offers this x-pipe.
Manufactured entirely out of 409 Stainless Steel, this X-Pipe will bolt-in once two simple cuts are made and the OEM segment is unbolted and removed. The new X-Pipe will reuse the two factory clamps found on front and Ford Racing supplies two new clamps to use on the rear section after the appropriate cuts have been made.
This will make the factory exhaust sound better and more aggressive, but also has a weight savings of 15 pounds. The Ford Racing resonator delete x-pipe does not require any welding or a tune.
For more X-Pipes available at CJ Pony Parts check out:
Mustang X-Pipes | CJ Pony Parts
For more 2015 Mustang parts available at CJ Pony Parts check out:
2015 Mustang Parts & Guide | Free shipping | CJ Pony Parts
