Hate Buying Razors?
  • Hate Buying Razors?
    If you're like me, you cringe when you buy a box of new razors for $30 that will only last you couple of months (I shave about every 3 days). Well, I came across this article a few weeks ago and started doing it. Still on the same blade and each time, it's sharper than it was out of the package.
    Simple enough, I may try it as soon as I get home.
      fuck shaving, i had to shave every fucking day in the military. since i've been out i have only shaved twice. once for a job interview the other for a wedding
      now i just knock it down with a beard trimmer or the clippers every few days
        I'll give it a shot. Another tip I picked up somewhere was to dry your razor off after using it.
        Vortex rear stand $75
        8.8 410s. $50
        **SKAGG NASTY**
        1990 Foxbody GT for that ass
        11 4 door
        13 FX2 White 5.0
          I hate shaving but I cant stand a itchy beard even worse. Ill have to try this trick when I get home.
            I can make one razor last about 3 months. Seriously. Shave two or three times a week too.
              Does it fuck up your jeans over time?
                A Sams club card and $40 will get you 30 blades....I hate shaving as well seeing as I need to everyday just to keep the itch down
                Originally posted by Sean88gt
                  Nah because you're not shaving them. You run the razor in the opposite direction. I suppose if you did it on the exact same spot on your jeans each time, it would fuck them up over quite some time, but probably not any quicker than normal wear.
                    Bad ass. Gonna have to try it. But I usually can make a razor last more than 3 months. But I also don't need to shave everyday.
                      I have to shave every day for work fml
                        I shave every 2 days, and my blades are done after a week. I'll give shit a shot.
                          Interesting. I shave every other day and won't buy razors until I can get a deal on a large quantity of decent disposables from Costco. This is too easy not to try it.
                            I really think denim will work better but I could be wrong.
                              Will try! I know the biggest issue for me are the gel coats on the razors. Not have those is a bigger issue for some reason than the blade itself. I still use shaving cream but something about those gel coats that are on the razors help with irritation and gliding across my baby face.
